Ok, I tried to install a frantz filter on my transmission its a 99 dodge ram with a gasoline 360.
I had a remote full flow filter already installed on the transmission cooler line so I installed a perma cool 181 sandwich adapter and the frantz with the .040 restrictor on it and checked the flow it was squirting out really good. Took it for a test drive and after it warmed up it was making a buzzing sound. I have a transmission temp gauge and it was still at 125 degrees so it wasnt overheating or anything. Got back home and popped the hood the buzzing noise was coming from the sandwich adapter. I can't explain it. It just buzzes. Sounds like the spring is bouncing around in its channel and when I put my hand on the remote full flow filter I can feel it vibrating.
I took it apart and drilled a .040 hole in the sandwich adapter put it back together and same thing. Any ideas how to get this thing to stop buzzing?
