I don't own a scanner that would allow me to get a live pressure readings at different rpms. I'll see if a local auto store can do that for me this weekend. If the pressure is within norm that will rule out the pressure relief valve.
The filter bypass valve doesn't operate from the engine oil pressure, it only operates from the delta-p across the filter media.
Monitoring the engine oil pressure under normal driving conditions will tell you nothing about if the filter bypass valve is operating correctly or not.
Have you physically checked out the filter bypass valve in the filter housing to make sure it moves normally and isn't locked up or sticky?
Try to keep up with a conversation and read more carefully. I was talking about oil pressure RELIEF VALVE, not an oil filter bypass valve. Also, don't quote incomplete snippets thus making wrong insinuations.
You don't have to be an [censored] about it. You weren't following what I was saying. Why such a flippant response?
What you should have said is that because oil filter has a bypass valve, even if the engine oil relief valve malfunctions it will not cause an excessive pressure differential (the delta-p term you like to use so much) across the media to cause a collapse. The only two ways an oil filter can collapse in this case is a) when the plastic cage is weak enough as to not withstand the pressure at or below that of an oil filter bypass valve as designed by a manufacturer, or b) when the oil filter bypass valve malfunctions and does not relieve a pressure across the filter media as designed.
But thank you for leading me to think about it anyway.
Don't tell me "what I should have said".
Yeah, pretty much what I said. So did you check to make sure the filter bypass valve is operating correclty, and isn't locked up or sticking as I previously asked. Obviously, you haven't thought about other possible causes of the failure all the way through, so yeah, your welcome.
I just gave you the taste of your own medicine. Because you didn't follow my post, twisted the words around and came across as an [censored] in the first place. If that was not your intent, and you simply don't realize how you come across sometimes, at a personal level I didn't mean to offend you. It's just between you and one other individual both have been insinuating ridiculous things on this thread. Water under the bridge on my side. Hope you are strong enough man to feel the same.
The bypass valve which is a part of the housing is perfectly fine.
