- Joined
- Nov 29, 2023
- Messages
- 554
I'm performing an oil filter housing reliability upgrade on a Pentastar V6 PUG engine. We have two of these. The other one actually started leaking coolant at 6,000 miles. I replaced it with a Dorman 926-959 aluminum cooler. The job went relatively smoothly, though it took a little while because I went extra slow to avoid breaking anything. I used Mopar gaskets for the cooler housing, the Dorman gaskets for the oil cooler (the two that are between the housing and the cooler), and Fel-Pro intake gaskets.
The first time I had to remove the oil pressure sensor connector, it gave me a hard time as well. However, I got some rubber gloves on, put the connector in the open position, and firmly pressed on it with my thumb while also slightly moving my thumb upward. And it popped off.
This time around, that didn't work. As you can see in the pictures, the connector is in the open position. I also soaked it a couple of times with silicone lubricant, but that didn't seem to help either. If anyone has any ideas on how to remove this connector, please let me know. I would be very grateful for any help. I just don't want to break the thing.
Apparently Hirschman Automotive makes these connectors, and this one is called "3way 1.2 SealStar FA Connector". I'm not sure if this info is of any use. I couldn't find any info from them on how to disconnect these. It's funny and sad that something so apparently simple can sometimes turn into a headache.
Thank you.
Thank you.
