If those are the vehicles you are "responsible for" somebody (or, someBODIES) took exceptionally good care of them in the past.
I guess what I'm trying to say is that, excluding the possibility that all of the engines were recently completely rebuilt, all have (excepting the Acura) over 100K miles on them.
Someone (SomeONES?) took great care of them. The proof is there to see.
Personally, in VA I doubt if there are any drastic climatic extremes that would warrant the use of either 0W-20 or 20W-50 from a longivity sake.
The factory recommendation of 5w30 for all is a pretty good starting point. Personally I would also consider a 10w30 (GASP!) simply because they all have in excess of 100K miles.
Bottom line: set up an OCI schedule for each vehicle based upon th type of NORMAL use, i.e. shorter for towing and a lot of stop & go miles, longer for highway use, etc.
Then I would pick just one weight: then buy either the 5w30 or 10w30 oil whenever on sale by the case (with rebates, of course) plus filters (either when on sale or as part of an "oil change special") and stock up. Dino, SemiSyn, Syn: all of it. Try to have at least one extra filter available for each vehicle.
NAPA often has filter specials for 50% (or more!) off. The very common "$12 for 5+ quarts and a filter" is a good deal, especially if there is no rebate to deal with. And $8.99 for the same deal is even better, IMHO.
Then just change the oil & filters on schedule. Well-maintained vehicles (as all of yours would seem to be) just flat last.
And they can last a long time, too!
I really don't believe that one SM/GF-4 oil is really any less capable of protecting an engine than another, excluding longer-than-normal (whatever THAT means) OCI's. Nor that you need Dextros in every GM vehicle now that there is a Dextros spec.
You could go to COSTCO and buy 6 cases of Chevron Supreme 5 or 10w30 and use it for all those vehicles and really never see a major OIL-RELATED problem, nor should you expect one. A broken timing chain, failed water pump, underhood fire, etc. may all result in a serious problem but you can be confident it won't be because it was 5 vs. 10w30, or PYB vs. VWB, or SynPower or AMSOIL, etc.
Just my humble opinion.
Cheers!
p.s. You could also go with a HDEO 15w40 in 55 gal. drums and never see an oil-related problem, either. One delivery and a trip to NAPA for a list of filers could keep you going for year or two.
