Ford Debunks Myths
NJ
http://www.imakenews.com/lubritec/e_article001711554.cfm?x=b11,0,w
Quote:
Ford decided to debunk a few of the most popular maintenance myths, including the following:
* MYTH: Cars need oil changes every three months or 3,000 miles.
False: That used to be true, but not with newer cars. Because of synthetic oils that don’t break down as quickly, consumers actually don’t need oil changes as often – more like every 5,000 to 7,500 miles. (There may be two recommendations for oil-change intervals: one for normal driving and one for hard use. Check your maintenance guide to be sure.)
SAVE: Either way, there’s a considerable savings here: Let’s say you’re an average consumer who drives 12,000 miles a year, which means you would need about four oil changes a year under the old formula. With the new extended mileage, consumers need only about two oil changes a year, cutting their bill for oil changes in half – you could pocket upward of $50 a year or $650 in the lifetime of your car and do something to help the environment by saving oil.
* MYTH: You need to let your vehicle engine warm up in cold weather.
False: Your vehicle’s engine only needs a warm-up period of about 10 seconds – you’re actually the only one who may feel chilly. The engine warms up while you drive. Running your car any longer beforehand is just a waste of gas.
SAVE: Depending on engine size, temperature and other variables, modern cars can use about a third of a gallon of gas per hour while idling. By giving up that 10-minute idle every weekday morning, you could save more than a gallon a month – $32 a year or $416 over the life of the vehicle.
* MYTH: Premium gas is a treat for your car.
False: Unless your vehicle is specifically tailored to take advantage of the higher octane level in the fuel, you’re wasting your money. Go by what is recommended in your owner’s manual and leave it at that.
SAVE: At current gas prices, drivers may save up to $150 a year by opting for unleaded gas instead of premium.
* MYTH: The number listed on the sidewall of your tire is the recommended tire pressure. False: In most cases, this is actually the maximum pressure allowed for that tire. The recommended amount of pressure is usually listed on the inside door panel – check your owner’s manual to be sure.
SAVE: The government estimates that the average driver’s tires are underinflated by 26 percent. Generally, underinflated treads lower gas mileage about a half percent for each pound lacking when the pressure of all four tires is added up. An average driver with underinflated tires could add $79 a year to his or her fuel bill – or more than $1,027 in the lifetime of the vehicle. You could also save nearly half a barrel of crude oil per year by keeping your tires inflated to the manufacturer’s recommended level. Per the EPA, one barrel of crude oil equals 42 gallons of gasoline.
* MYTH: Buy gas in the morning and you’ll save money.
False: The old adage was to fill up in the morning when gas was coolest and most dense because gas is sold by volume and you would get more gas for your buck.
But gas is sold in underground, nonmetallic tanks that typically hold about 10,000 gallons, and it will take a lot of sunlight to raise the temperature even a degree. (However, pumping your gas when it’s cooler does mean less release of vapors, which is better for the environment.)
SAVE: Do your research before buying. Ford’s SIRIUS Travel Link™ sorts gas stations by price on the navigation screen, but Web sites like MSNAutos.com can also help drivers navigate to bargains. In our quick research, we found two gas stations in New York City – less than a mile apart – with 30 cents per gallon price difference. If you know before you go and fill up for less every time, it could result in $227 in your pocket annually, or $2,951 saved over the lifetime of your car.
All totaled, by implementing small changes, drivers could save up to $538 a year or $6,610 in the lifetime of their vehicle. In today’s economy, every penny counts. That’s why it’s important to get the facts.
I like!
A little marketing thrown in there but over all, factual... I'd add with the tire pressure I've found in my vehicles if you bump it up 2-3 lbs over the door sticker you get slightly better MPG and tread life.
Bill
Originally Posted By: Bill in Utah
I like!
Bill
Bill,
I actually practice the same thing as you do with the pressure.
See, we can agree on some things.
Originally Posted By: sangyup81
Way to go Ford!
+1 A lot of what we already knew but still......Nice job Ford!
take it with a grain of salt: manufacturers make money by making more vehicles, so they MUST make sure the vehicle breaks down just as soon as the warranty is over. what better way than to encourage the owner to save a few pennies on oil, and then end up buying a nice big brand new shiny FORD, which stands for:
"found on road dead" and "fix or repair daily". after the head gasket blew in my Crown Vic, and then TWO oil pans rusted out in my Econoline - no more Ford for me, never ever again.
I don't think so. Vehicles last a good long time. They're rather complicated at this point making them expensive to repair. That's how they get you to buy new future junque. A $4000 trans rebuild for a $3000 retail car that has literally a hundred thousand like units in the field really isn't going to need to self destruct @ 100,001 miles.
Affordability will limit car sales now. They're too weighed down with supporting various advocacy groups and agencies that promote consumption. We can't afford to be this safe and pampered.
Doom and gloom because you floored your Vic at the stop lights and never washed the underneath of your van.
In Canada all fuel pumps are temperature compensated to 15C/59F degrees, so the gas temp is irrelevant.
Thats Chryslers business model.
Way to go Ford!
+2
Also +2 on bill in utah's comment!
Nice - and although I believe all that, I still have a hard time letting my car warm up for only 10 sec's before driving on a freezing morning...
I know that logically I should not worry, but it's really hard for me not to.
Jebus, where did that Econoline sit, in a salt mine?
My '02 Econoline E-150 XLT is the best truck I have ever owned. It has the towing package with the factory hitch, oil and trans coolers. I have ran Amsoil and Pennzoil synthetics it's entire life of 144K thus far and only the brakes, front end and shocks, plugs have been replaced.
The 5.4 doesn't leak a drop of anything and I ran the Superchips 1715 Engine Controller on it and put the 87 octane program in it. It has two other levels of programming, but I kept it with 87 octane. I defeated the speed limiter and firmed up the shifts in the trans and raised the shift points.
Ford makes a fine vehicle, it is too bad that you had some weird maladies. Blowing a head gasket is hit or miss, but I have never heard of the oil pan thing.
How much oil would we save nationally if we could get rid of the 3000 miles 3 months? I know that a lot of Jiffy Lubes would go out of business, but would that be so bad to reduce oil usage???
The same engines used in the Vic are used in the Mustang and they aren't known to blow headgaskets...and I bet the average Mustang gets more abuse than a Vic (unless said Vic is in taxi or police service).
None .. I think. Once the crude hits the cracker to make fuel you need to do something with the residuals.
We use a lot of fuel.
I doubt most people change their oil every 3,000 miles.
Even those who say do, are never on time, and the interval is often extended to 4-5k.
