Ford 4.6 oil pump pickup
Manitoba, Canada
Im going to change the timing changes and oil pump in my Mustang. I wan to do the oil pan gasket too. There are two 8mm bolts on the pickup tube that attaches to the oil pump. Is there another bolt that holds the pickup tube to the engine block farther in? Im trying to remove the pan without lowering the K member.
