Since buying this car, approx 166K miles, I had the following problems and resolved them as follows:
-P1233 code: Replaced FPDM, didn't fix it, so I did an electrical test and repaired a broken wire and that fixed that problem.
-P0152 code: Replaced B2S1 o2 sensor with Bosch direct-fit (not universal junk) sensor and that fixed that problem.
-Replaced MAF sensor... compared to the two Crown Vics I've had before, the car just didn't seem to be running right, and it shifted "weird" - I also cleaned the throttle body while I was in there (it was pretty clean, I don't think I'm the first person to clean it lol). Anyway the car is sooo much better after changing the MAF sensor and all that. I cleared the codes, it set the emissions monitors just fine, and it passed the smog so I could register it, great!
Only thing is... something is still wrong. Do I have to fix it? No, the car runs and drives OK, but I'm picky and I want it to be perfect. Fuel trims are good, no codes are set. I have maintenance history for almost everything from 0-150K and then it was privately owned for about 15K miles and I have no maintenance records in that time. I did some digging into the seller's Facebook profile after I bought it (oops) and the reason he sold me the car is he thought the transmission was going out (due to the bad MAF sensor lol). Anyway, I don't see anything for spark plugs, maybe they're original - would that cause this issue? Btw, I know they are a bit of a pain to change and likely to blow out of the cylidner head if not torqued properly - which is why I haven't changed them.
On to my issue, is that it just doesn't feel like the engine is running like it shuld. My 99 civilian Vic and my 07 P71 which was basically identical to this one both idled a little smoother. I wouldn't go as far to say as it's a rough idle it's just not completely smooth. And it runs fine and has plenty of power, I just feel that it isn't quite as responsive or peppy as the 07 was.
Where do I go from here?
