For all the 5.0L naysayers
Originally Posted By: IndyIan
So is Chevy smarter than everyone else? Sticking with 2 valve OHV V8's for the Vette? I guess the trade off is a more displacement at lower rpms to make equal power, but with much physically smaller, lighter, and simpler engines?
I guess the ZR-1 shows that the KISS method can take on almost any techno-wiz car. I think the main drawback of the cam in block is that they can't have variable valve timing? Or atleast seperate intake and exhaust timing changes. Maybe 2 cams would fit in the block?
cam within cam is already used in Viper V-10's. New gen Eagle Hemi moves a single cam in block a huge amount.
My whole focus was on the complexity. Not the peak performance. My old 6.1 can easily go 180 mph and not even ripple your latte. And it does it cheaply and reliably.
Note that my retired airline pilot bud has already had his 5.0 in the shop for a couple of minor issues, and his gearbox is occasionally a bit balky. It's far from the "perfect car".
Originally Posted By: Nick R
Originally Posted By: Rand
I dont understand your post.. are you saying it has pushrods or making fun of pushrod engines or what?
I'm saying I want to see a 5.0L Pushrod V8 that can do that.
We have a 632ci BBC That makes 1100 hp on motor and 2000 on spray and is turned at 10,000 rpms. Launches at 4800 rpms. So yes you can make power with a pushrod engine. Don't see too many DOHC pro mods......or any...
Just like factory sound systems are far better than what we used to put in as aftermarket upgrades, factory engines are insanely good now.
I realize that there are guys who still live in the Civil War, and also take sides Chevy vs. Ford.
It's nice to know political correctness did not kill the American muscle car.
Originally Posted By: SteveSRT8
How about posting up the info on that 5 valver Dparm. Seems like it let go a bit early as well.
LOL what do you want to know?
Are OHC's allowed in Pro Mod? I know guys used to run the 427SOHC in ProStock "back in the day" but didn't know if they were able to run in ProMod or not.
In Nick's defence, he did specify 5.0L pushrod and I assumed we were just talking about street cars not drag cars. The 815+ ci ProStock Mountain Motor cars make 1800+HP on motor and they are pushrod too
I'm with you. Not to say the 5.0L Ford is bad at all or to make it a Chevy vs Ford thing (Nick did say pushrods though), but I'd take the GM LS3 6.2L with 430HP 424 lb-ft. For most all purposes even with pushrods it does everything this 4V 5 L does.
http://www.insideline.com/ford/mustang/2...-camaro-ss.html
Quote:
Yeah, the straight-line performance is agonizingly close (and apparently varies car to car), but that doesn't mean the power plants of the Camaro SS and Mustang GT are clones of each other. With its advantage of 1.2 liters in displacement and old-school pushrod valvetrain, the Camaro's 6.2-liter LS3 V8 makes big chunks of torque down low in its power band (it peaks at 420 pound-feet at 4,600 rpm, but also makes plenty right off idle), and then pulls strong until it starves for air near its 6,400-rpm redline. It's a throwback engine with great bottom-end grunt and a pretty good top end.
In contrast, the Mustang GT's 5.0-liter V8 puts its deep-breathing 32 valves controlled by dual overhead cams and variable valve timing to work, starting off a bit soft at the bottom end (all its 390 lb-ft of torque aren't available until 4,250 rpm), then pulls mightily through the midrange until it's screaming at its 7,000-rpm redline. This is a 21st-century V8, combining pretty good bottom-end thrust with a great top-end thrill zone.
Don't know if they are or not. I do love pro stock but our budget doesn't allow it. Automatic pro mod is still hard for us to do but is the closest class for us to run in. Still trying to get the bugs worked out of the new truck on its first year out.
But Nick said 5.0L, and you just brought up a 6.2L........... Increased to 6.2L, the Coyote would be making 550HP.
However, Ford DOES make a 6.2L (Hurricane), it is only in the trucks, but makes 411HP/434lb-ft.
Nothing wrong with either approach. Dual VCT simply allows you to make the same power from less displacement more livable by providing the ability to move the power band around.
Got any pics? (OT I know) if so, you should post them in the pics section
I'd love to see 'em!
I love this argument.
Ford guys poke fun at the GM guys for having "low-tech" pushrod engines. GM guys defend by talking about big power and high revs in the LS7.
GM guys make fun of Ford guys for being stuck with "low-tech" Macpherson struts and a live axle rear suspension (What does a Boss 302 and Nick's Cruze have in common? Struts up front and a live axle out back). Ford guys defend with lap times from the Boss 302 Laguna Seca.
...and on and on until the world ends.
One wonderful thing about the LS platform is that it's a straight up hot rod engine. Mix and match parts that make good power are readily and inexpensivly available at the wrecking yard. Running it carburated is no big deal if one doesn't want to deal with electronic controls. Power is available no matter how you build it. Most important of all, and key to the populatrity of the platform: It fits anywhere an old small block fits! That means it's nearly universal for everything GM has made in the past. It's a master key to power any GM car or truck.
Well put
I have to hand it to the guys shoe-horning 32V Modular engines into the fox body cars. It is a LOT more work than doing a Windsor. But that's the spirit of hot rodding right there
The GM guys certainly have it easier with the LSx engines in that respect. They are a nice, compact package.
Shoehorning a 32V into a car that came with a 32V is a ford of black art sometimes.
The back and forth Ford vs GM chest thumping stuff gets old after a while, especially at car shows. Just went to my first car show for about 8 years last month and I remembered why I stopped going.
Well put
Shoe-horning more powerful engines is not a new idea. Just watch a documentary on Mustangs with the SCJ engine.
Well put
I've done a few engine swaps dude
My point wasn't regarding swapping in more powerful engines, it was swapping in an engine that is like twice the physical size of the engine that came out.
Well, yes, overkill. What I am saying is that during the 1960s most Mustangs had a 289, and putting a 429 SCJ was quite a job, because of the size difference.
Well put
Overkill, check out 2010 colorado in pic section. Posted them up for ya.
I know he mentioned 5L and of course a 4 valve has higher HP/L pontential. But it makes little sense to limit to 5L when an extra mere 20-30% of displacement with a pushrod 2V gets the same power output, equal or lighter weight, engine compactness, low center of gravity, fuel efficiency etc.
That's my point with as little as 24% increase in displacement you gain pairity or better to a 4V and really give up nothing. If you were giving up anything with the added displacement then it wouldn't be valid to give the OHV design extra displacement.
Originally Posted By: ARCOgraphite
I was a hotrodder but no place to run these babies anymore. I tromp almost everone on the road with a 1.5L - thats how slow and conjested traffic is. I was running a Porsche on the highway one night (in a rare moment for me these days) and even he gave up at 115mph while i was jammed up against the "warranty" fuel cutoff. What am I saying - more fun to drive a "slow" car fast than a fast car slow. My last muscle car was a Bullitt "stang '01. the V6 ponies are WA Ytoo fast enough for anybody. -
AFA overtuned - The Honda would make 400 hp if it was a 5 litre - and this isan "economy" stroker small valve engine. V8s have been ridculously detuned for ages.
so THATS what happened to the ranger and yaris....
But then we are going in circles
I mean Ford chose 5.0L for the obvious nostalgia associated with the moniker, and if the power increases linearly with displacement (which we can fudge and pretend it does here) then at 6.2L, the same DOHC engine would be making 550HP
The "limit" they've put on the engine's displacement wasn't a limit. They CHOSE to go that route, to bring back the nostalgia of the 5.0L and the Trans-Am era BOSS 302 to essentially create a modern-day version of the toilet-headed high-winding engine that the BOSS 302 was originally as well as tug on the heart strings of the guys that owned the 5.0L Fox body cars of yesteryear.
They don't even use this engine in the Shelby, it gets the venerable 5.4L. And if they REALLY wanted to, they could have used an all-aluminum version of the 6.2L from the Raptor which is rumoured to be able to grow up to 8+L, has a big 'ol 4" bore and even the truck heads flow incredibly well.
GM and Ford, like usual, chose different routes
GM went with a pushrod motor, decided to up the displacement and deal with the HP/L penalty afforded by not having the ability to control the timing of the intake and exhaust valves independently. Ford decided to forge on with the Modular series, but with a big upgrade in the cylinder head department. They kept the displacement ceiling relatively low because they were shooting for that all too well known "5.0" target
And its not like the cars the engines are going in are similar either. Like the 3rd gen F-body versus the Fox, they are pretty different.
And ultimately, I think that's a good thing
