Today's little effort...
Doing a partial change of the PS fluid in my '93 Bimmer. This stuff is supposedly "Lifetime Fill," much like the transmission and possibly the differential on the car. So I'm dealing with fluid up to 21 years old here... Great.
A year ago, I went to check the PS levels, and found the fluid was very thin, and very black. I ordered some Redline D4 ATF and simply haven't had the means to change it till recently.
I got a fluid transfer pump, pumped out the older stuff, used some of the new stuff to "flush" the pump, then added new ATF into the reservoir. Now, it at least has a pinkish tint to it.
The stuff I drained out stank to high heaven...
A do have a slight PS leak that shows up on the driveway every so often. So this will probably exasperate the leak. Still - I'd rather have a little bit of new fluid in there to keep the system properly lubricated and clean...
In time, I will slowly exchange the fluid. But for now, this should be enough, and I'll see if the leak gets worse or not before proceeding.
Anyway - the lesson is, please change your PS fluid. If it stinks, doesn't look a nice cherry red (i.e. blacker than the night sky). PLEASE CHANGE IT!
