Originally Posted By: IndyIan
In theory, shouldn't the oil passages should be sized large enough that they should act like a pressure "tank" so all the bearings receive equal pressure?
Well, the oil is incompressible so the galleries can't really act like a "tank." Ideally their cross-section *should* be large enough that they don't cause a significant pressure drop... but have you ever looked at an as-built engine casting? They're always rough and frequently have a number of restrictions where various parts of the casting mold meet. Many pushrod v8s also have the lifters partially intruding into the two main upper galleries, which reduces cross section somewhat. That's one thing that you can do *way* better than the factory when you rebuild an engine- just run a long drill bit down every oil gallery to knock off the roughness of surfaces and open up any obstructions. Oiling system reliability goes way up with nothing more than that. Its less of a problem with newer aluminum casting methods than it was with sand-core cast iron blocks, but it still isn't a perfect production process. Even in a perfectly prepped oil system, odd things can happen at high RPM though. Since the oil feeds into the main bearings and flows through passages inside the crankshaft to get to the rod bearings, the crank becomes a big centrifuge at high RPM and flings all the oil out to the rod bearings so that if any one main is a little low on flow, the crank can actually suck air *in* at the main and cause it to intermittently go dry. By the same token, when the crank becomes a centrifugal pump like that it starts "sucking" oil down the galleries causing faster oil flow and the pressure drop can get bigger. Not usually a problem in street engines, but it can happen.
