I have a 1998 Cadillac Eldorado with a 4.6L northstar that will be due for an oil change soon. I've been pouring Napa Premium Conventional into the crackcase. But I was informed by several people that because my car has flat tappet cams that I should use an oil with more zinc. And since they took zinc out of oil it'll be hard to find. I've done some research and some say that zinc is good for cams but bad for cats, others say that zinc doesn't protect flat tappet cams anyway. Etc... will it be bad to continue using Napa Conventional or should I try to find something with more zinc? My mechanic says oil is oil most cars don't benefit from synthetic and Napa is Valvoline and he sings their praises. Bottom line, if this was your car and you wanted that engine to last (aside from HG failure) what oil would you use?
