I read a Hot Rod article about using GM's EOS on breaking in a new flat tappet cam. The article then when on to say to use the 4 oz bottle of GM's cam and bearing prelube with every oil change. I have heard of using the EOS at very oil change to increase the zinc but this is the first I've heard of the cam lube. Anywho, I have a friend who gets the Clevite 77 cam guard lube pretty cheap. It has extreme pressure additives. Would this be the same as adding the GM cam lube as indicated in the Hot Rod article.
I can't seem to find what all is in the Clevite lube.
Another question. Many people are using the 16 oz. bottle EOS additive at oil change for extra zinc with there flat tappet cam. The GM parts man told me that GM does not recommend the EOS as an oil additive after initial break in. Does anybody know why? He didn't.
