Originally Posted by LoneRanger
This is the info I need right here. Mobil 1 traditionally has always seemed to make my motors emit more mechanical noise of operation for some reason. Is your 1.5 quiet with the Mobil 1 EP in it?
I'm using dealership oil. For all I know, they could be putting in 5w30 ! Right? Well, I assume its AC-Delco 0w20 anyway. Mine is a 39 month 39,000 mile lease though and I will likely turn the Equinox in when done instead of buying it. Therefore, I just monitor everything and don't care much. .... If I had bought it to keep forever, I'd be using Mobil1 EP or AP 0w20 or maybe M1 AFE 0w30.
I get 2 free oil changes, really 3 now since the dealership over-filled the first one and GM gave me a coupon because of it for a another one. I'm about to get the last free one. I'll probably have to drain a little out after they overfill it again.
When you change out the factory fill, drain it, fill the oil filter if you change it, and only put in 3 quarts to start with. Run it a bit and check the oil level in an hour+ after shutdown to get a real level. This thing over-fills easily because it is s-l-o-w to drain out. Owner's Manual directly warns about slow drain-down time. (I overfilled it a little when changing factory fill myself with Valvoline syn, and I put in 1/2 quart less than I thought it "should" take according to the rated capacity, so its easy to over-fill.)
