Buy the best you can afford and only cry once.
Why would you mention Hyundai and BMW in same thread?Bought a my first (and last) Hyundai last September, because we'd like to try Hybrid and Japanese brands all marked up.
Overall happy with our new Tucson 1.6T Hybrid since it has a smooth & quiet ride and thinking it should be reliable given they replaced previous gen's DCT with AT and 1.6T gamma engine is not under any recalls.
Unfortunately, car started making ticking noise since last week when driving uphills (we live in Seattle), it has just 7903 miles ODO. First oil change is due at 8000 miles.
Checked the engine carefully and noticed visible damage right under the oil filler cap, tho no check engine light has poped up:
According to my research, I believe the cause is the CVVD system drives the camshaft that hits the engine block, the damage happened here:
(Screenshot taken from some video)
I'd expect metal shavings in the *factory fill* engine oil lol
What's worse, because Hyundai now has 10/100k warranty their dealers are all fully occupied with their masterpieces, called 2 dealers today and the first slot to have someone look at the engine is early May. I may have to keep driving it.
Will update this thread if ppl are interested. Ironically this is the first time we had engine problem, other ride (BMW F30 / B48B20) is stonger than this Hyundai over the 7 years of ownership![]()
Actually their LG washers and Samsung TV’s are top notch. But anything on 4 wheels?I’m amazed at the number of complaints about South Korean products here. From appliances, to vehicles, to Lord only knows what other products we’re unknowingly consuming that might be substandard.![]()
I would say any car filled with electronics is a 10 year car before stuff starts to fail. My basic Accent will die from rust first as there just aren't a lot of fancy gadgets.Because they are throwing together disposable vehicles.
Eh, The Caprice and Malibu should have a million issues then. It depends on how you take care of it and what gadgets it has.I would say any car filled with electronics is a 10 year car before stuff starts to fail. My basic Accent will die from rust first as there just aren't a lot of fancy gadgets.
Manufactures need to bring back cheap basic cars.
How do you take care of electronic modules?Eh, The Caprice and Malibu should have a million issues then. It depends on how you take care of it and what gadgets it has.
Following so I can be enlightened as well. Good stuff.How do you take care of electronic modules?
They’ve basically shut down their IC engine lab. https://www.autoblog.com/2021/12/28/hyundai-closes-engine-development-shifts-to-ev/Why can’t H/K get their act together on their engine issues? You would think they’d have figured out the problem after 10 years of issues with them.
Like ABS? BCM? ECM? What ones are you talking about? The 2000 and 2005 have all that stuff too? Like the touch screen? The Malibu is at 105,000 miles and is LTZ has all that lane departure stuff. That car has not been back to dealer for anything. I am not sure I understand. Remember my job is based off repairing and troubleshooting electronics on Submarines. Like you can clean an inspect your connections, keep the cars parked inside, make sure they are not getting inundated with moisture. I guess I could have worded it better since you can't open all of the modules on any car.How do you take care of electronic modules?
How does bmw, audi, and others manage to have no issues with their dct transmissions yet Hyundai does?they all tend to get shuddery around 50 k miles. If that's within the warranty you're lucky as it's not just the clutches but often the clutch forks are bent and the actuator has so much play it needs replacing.
VWs dsg wears out the clutches eventually and the dual mass flywheel gets hammered on the TDIs and starts rattlingHow does bmw, audi, and others manage to have no issues with their dct transmissions yet Hyundai does?
I think everyone is pretty booked up. At least around here. People keeping their stuff longer.Three weeks also at my Ford dealer
