Originally Posted By: NHHEMI
Originally Posted By: Blue_Goose
I'm probably going to change out the FF at around 3K if not a little sooner.
1st Chrysler product (other than a 75 Valiant which seems like a million years ago) I see for warranty purposes they ask you to use a oil that meets the Chrysler Specs
I understand the FF is 5W20 PYB. I'm thinking of either sticking with that or PP or PU. I see that Royal Purple also carries the Chrysler spec as well.
Out of the 4, suggestions? Weather is turning colder here finally. Plan on putting a Fumoto drain valve too. Really liked how it worked on my Crosstrek.
PYB, PP, or PU will all be good choices. I am a big RP fan and that would be my choice however. I have used their API 5W20 and it has done well. Good UOA's in a 2.4L Patriot and 5.7L Ram with it. Was going to run it in my 2014 Cherokee w/ 3.2L but had to sell the vehicle before I could get to it.
Another option for you is Kendall GT1 blend or full synthetic. They have 5W20's that meet your warranty requirements and their oils are excellent. Very affordable if you order online from PSC( 2 cases at a time for best shipping deal - more cases does not increase the deal - 2 is best always ).
http://www.petroleumservicecompany.com/kendall-gt-1-fs-w-ti-5w-20.html
http://www.petroleumservicecompany.com/kendall-gt-1-sb-w-ti-5w-20.html
One small caution for you. There is a new oil filter starting in 2014 for the 3.6L( also used in the new 3.2L ). While similar to the earlier filters they do not work in the 2014+ engines. I would assume by now that the parts listings have caght up but earlier in the year many people were being given the 2013 and earlier filter and I guess they fit( sort of )and some people damaged their engines. Just make sure you get the correct filter for 2014+ engines.
Also, the filter is a cartridge type filter and there are very few quality options available for it( at last check anyway ). Most people run the MOPAR/OEM filter.
MOPAR# MO349
Factory OEM #: 68191349AA
Wix #: WL10010
I got a Fram CH11665 to use. I didn't see that one in your list although Fram lists it as the correct filter.
Any ideas on that one?
