First chance to use my Ribe socket set
Suburban Washington DC
On rear seat mounting bolts
Bought this set on Amazon 3 years ago for under $12. No idea if I would ever use it, but at that price....
Look at the two photos- the Ribe socket teeth are square edged. The seat anchor bolt has rounded edges.
That’s not a Ribe bolt.
Looks more like Torx Plus.
+1 Torx Plus. Not Poly Drive or Ribe. Edit, I thought they were the same but apparently there is some difference. I only have a couple of Poly drive for VW
Is Torx Paralobe being used on vehicles?
The TORX PARALOBE™ Drive System was developed as a result of listening to our customers’ needs and concerns with other drive systems. It also improves upon the benefits of our TORX® and TORX PLUS® drive systems by offering increasing drive bit strength, life, and increasing torque; 20% over the TORX PLUS® drive system; 50% over the TORX® drive system! The TORX PARALOBE™ Drive System features unique geometry resulting in ‘full surface drive contact’ to reduce drive bit/recess contact stresses.
