- Joined
- Sep 28, 2002
- Messages
- 39,798
It's not "maintenance" ..it's an art ...a craft...lovingly performed with care.
Quote:
Yes, as the day of the oil change approaches, one can start preparing: pre-fill the filter, remove the rings from the bottle caps, relocate the oil bottles and filter to the workshop (or in winter to a warm place so more oil comes out of the bottles). All this helps to build the momentum and excitement so that on the day of the change, you can hardly stand it anymore and are ready to jump right in. It builds up to the climax when you pour the new oil in. After that it's all cleanup and disposal.Quote:
I've been pre-filling my filters prior to the oil change. I like to do it the day before so that the media soaks it in. Then I top off the filter just before installation.
Quote:
Mark me as another pre-filler.
Heck, I even do it on my BMW cartridge filter - I have a coffee can that I soak the filter in (new GC) and let it saturate, then drain it a little and put her in the housing. The oil left in the can then goes in via the filler. (of course the coffee can is kept pristine and stored with plastic lid in place...)
Quote:
Ducatis' recommendation may very well be an issue with the oil pump priming. John Deere had problems some years ago with oil pumps not pressurizing the system after an oil change. The solution was to drill a very small air bleed hole in the pump housing outlet side. Maybe Ducati has a similar issue and the pump needs zero froward pressure to prime ie an air pocket in front of the pump? I have always prefilled my oil filters whenever possible and never an issue with my vehicles.
