Originally Posted By: ZeeOSix
... Therefore, the ADBV should always keep the entire oiling system full of oil if it's working correctly.
In theory yes, but in practice on the engines whose oil I have changed, my observation is:
- Remove the filter shortly after shutdown and oil gushes out from the engine.
- Remove the filter after the engine has been off for 12+ hours and no oil flows out.
My conclusion is that the ADBV slows down the reverse flow after shutdown, preventing sudden backflow, and apparently that is all the manufacturers expect of it. Gravity eventually draws down most of the oil above sump level.
