ToyotaLover67
Thread starter
- Joined
- Jun 3, 2023
- Messages
- 23
It's called "Called Global Multi Vehicle Transmission Fluid." Suitable for use in Dexron VI, Mercon LV, Mercon V, ATF+4 and most foreign transmission.Unless this fluid has the specification your car calls for printed on the bottle (not "meets" or "exceeds" or any other marketing word) your "contaminated" fluid was much closer to what the manufacturer specs.
On the back it gives vehicle makes it is compatible with. Toyota, and Lexus are on the list.
Not using this fluid in the car, nor will I start it with this in there. Will only be using it to flush, drain, then button up, and refill with OEM.
Might be a few ounces that mixes with the OEM stuff, but considering it's compatible, and ATF, not oil I think it it's likely better.
