Examples of "low quality" oil?
Interestingly, this is where Mobil's (and I'm sure there are competitor products) EHC "Group II+" (Group II) products enter the picture, due to exactly that problem. The standards and performance requirements drove up formulation costs, so the industry worked to find a way to drive those costs back down.
There's now even a new ultra-low viscosity EHC base, EHC-20L (2.1-2.6cSt) for formulating the new ultra-light grades while avoiding the cost of Group III.
And last time I checked - over two dozen well known formulators were buying EHC …
Quick lube places know that car manufactures request oil sample before they pay warranty claims on blown engines. They do not want the litigation and bill for engines sent out with non spec oil. In fact they will tell you no to conventional oil if your engine calls for synthetic.
What exactly would an oil sample show on a catastrophic engine failure?
Group III is a collection of mostly saturated branched hydrocarbons that started with crude oil or natural gas where the molecules were broken and rearranged by man to create a higher performance base oil.
PAO is a collection of saturated branched hydrocarbons that started with crude oil where the molecules were broken and rearranged by man to create a higher performance base oil.
POE is a collection of saturated branched oxygenated hydrocarbons that started mostly with crude oil where the molecules were broken and rearranged by man to create a higher performance base oil.
The end result is higher performance base oils that the industry has chosen to label synthetic.
Who cares how you got there.
And those two are sometimes used in harmony by man …
Whether it was still serviceable and the viscosity both of which would be something most BITOGers would want to see if the question of a blown motor/UOA was posted here that would be reasonable to look at in that case if they ask for a sample.
Whether it was still serviceable and the viscosity both of which would be something most BITOGers would want to see if posted here that would reasonable to look at in that case if they ask for a sample.
The uoa’s I’ve seen after catastrophic engine failure don’t provide much useful data of what oil was used prior to the failure. Not a tool we used to determine warranty denial at the dealership. Not to mention oil related failures are as common as getting struck by lightning.
I have no idea about what the various manufacturer's look at/ask for/need to approve warranty claims like this but to me, this would be reasonable to do and could provide some clues i.e. oil way out of the recommended viscosity range, depleted/oxidized oil etc. that could indicate a lubrication issue or abuse.
To be honest most uoa’s we did on non catastrophic failures showed a drop in grade on our bulk oil. Not a tool our dealer used often for warranty denial, mostly looking for glycol.
Regarding the topic of engine failure and oil samples ...
I would think the obvious things they are looking for are gross negligence of required maintenance. We've all seen the videos from "Just Rolled In" (and other similar YT channels) where it's incredibly obvious that oil changes were simply ignored, or improper fluids were introduced (think of someone putting washer fluid in the engine, etc). These kinds of things are quite obvious and are going to be cause for a warranty denial. This is because the failures are quite glaringly atrocious; just an affront to any gear-head sensibilities.
But if an engine seizes under warranty, and the oil "appears" in good shape (it's dark in color, it's not milky, it's thin and not molasses-like and the filter isn't sludged up), then there's no real reason for a dealership to pay the money for a UOA. They're not going to suspect that a SN or SM was used where SP was "required", mainly because there are not outward tell-tale signs of horrific abuse. If the vehicle is a sports car, or a modded diesel truck, they are much more likely to pull the engine programming history and see if the engine has been "tuned"; that would be something they might well be interested in.
I have my serious doubts that any dealership would spend the time/money on worrying about oil brand/grade/spec used as long as there's no outward indication of lubrication problems ( such as sludge under valve cover; sludge on filter media; milkshake oil; coagulated oil; no oil present; etc ... ).
Which is essentially the definition of "synthetic", unless we want to get extraordinarily pedantic about the literal dictionary definition.
And that's my point - at this point, all oils are practically synthetic or something awfully close, so the marketing distinction is just marketing fluff.
@Tom NJ has the right of it who cares how you get there!
