Question about OCIs and conventional/synthetic oil
If a person has their oil changed at Valvoline Quick Change or Jiffy Lube, is it better for the vehicle to have the oil changed every 5K miles using full synthetic or every 3K miles using conventional and synthetic blend oil?
The car in question has direct injection and is driven in a mix of city and highway.
IDK that you can find a true "conventional oil" anymore, not one that has the latest certs.
To answer your question, any oil that meets the spec listed in your owners manual, changed at 5K miles with the filter, will be fine.
If I could absolutely not change my own oil I’d honestly go to a Walmart service center and pick my favorite oil and filter off the shelf. 5k no problem, possibly longer depending on your driving conditions.
It's possible for a pure group 2 conventional which meets the SP and gf-6a requirements to exist. Chevron havoline comes to mind. Their 10w30 doesn't say syn blend and the website also categories it as a conventional yet it meets the latest SP gf-6a requirements. Their 5w30 does meet the SP gf-6a too but it states it's a synthetic blend and both cost the same.
  • Like
Reactions: wlk
What mix of city and highway? How many miles racked up in 4 months? How is it driven?
For a short or moderate OCI these is no need for "synthetic" unless it is a GM vehicle requiring DEXOS lic.
They will both meet/exceed ILSAC GF6A/ API SP.
Now what is this mystery Vehicle? I can't really make any recommendations without knowing specific use pattern and marque/model and powertrain
- Arco
Rog...but I doubt his vehicle calls for 10w30
Just about nothing made after the 90's has 10w30 on the oil cap so it's a low chance but what grade his vehicle uses wasn't in the topic. But like I said it's possible to make a "true conventional" (no group 3/4/5) meet the latest gf 6a and SP rating but it's difficult. It can't be done with 5w-20 or 5w30 from what I've seen and must be synthetic blend at minimum for those grades. Also what does rog mean.
Valvoline conventional 10w30 has SP rating and is conventional per product description. There is a couple but not many.
more info!! your car + engine + of course location as temps are important when choosing a lubricant + driving style helps!! as noted an honest indy is best if you dont DIY it
Keep in mind every time you change oil you get a bit of dry start, and some of the additives that 'plate' to metals wash away and have to 'plate' all over aga
- Arco
Maybe 50/50 city and highway. Maybe 2000 miles driven within 4 months.
2019 Kia Rio with 1.6L direct injection.
A gentleman above was doing 6K OCI on his Kia. He said the oil was in bad shape so he switched to 3K OCI.
@ARCOgraphite
3k OCIs is smart business with Kia and Hyundai TGDI / GDIs
Next two smarts are keeping the dipstick oil level at the Full Mark and use SP 10w30 or 0w40 oils, Euro or EP, doesn't matter..
@ARCOgraphite
The 1.6 is a good engine. 5k is a good interval. Boils down to your preference. 5k will do just fine, but if you can’t sleep over that then just do the 3k and be done with it.
It is under warranty so I don't think I can use anything heavier than 5w30.
If I maintain it well, any opinions on how many miles I can get out of the engine before it goes kaputz?
Sorry, current tools are not working for that. :unsure: :ROFLMAO:
Most on here say good earlier changes "should" help prolong the life, no clue until when, probably until just after warranty expires.
I'm helping maintain the 2.0L Hyundai Tucson with same dilema except for the added UOA information.
Is that what your owner’s manual says that the warranty is predicated on grade? Something to the effect of “the new car warranty will be voided if any grade other than… is used”? My manual says that using an oil that causes damage may void the warranty. Is yours different?
Using a somewhat heavier grade will not cause damage. In fact, quite the opposite. It will help to prevent damage - as long as the winter rating is appropriate for the starting temperatures.
