- Joined
- Jun 30, 2023
- Messages
- 320
Here is mine back in 2023 with 239K on it. I just turned 285K yesterday.
It would be interesting to mic the lobes, see how much is gone, and then see when misfires occur.Its not a bad job. Get the correct angled feeler gauges and the valve adjustment screwdrive tool thing. Also a VCG and Hondabond HT if its more than a couple years old. Took me 2-3hrs taking my sweet time and triple checking everything. At 150k-ish all could use a little adjusting. Nothing crazy out of spec and it runs just the same.
Im not replacing the cam either way. Mine looked normal, I guess. Proper gasket installation is always essential. Also use a quality gasket and Hondabond, not the parts store RTV. "The right stuff" would probably work fine but its not any cheaper. Also clean the surface of old sealant and 100% of oil with brake clean. Tighten in the right sequence. Don't bother with a torque wrench. Use 1/4" drive rachet. The grommets bottom out when tight enough. With quality parts and proper install it won't leak. Most likely it will be a better job than the average ahop.It would be interesting to mic the lobes, see how much is gone, and then see when misfires occur.
Bit reluctant to remove the VC as I replaced the gasket once, only to have the garage replace it again. Maybe it does need RTV to do it right, or maybe they replaced it because I did not clean any oil off the engine (it was leaking in other spots too when I had it repaired). I probably should mic the clearances and see what they are at, just haven't felt like touching it.
I use M1 on ours, but I firmly believe in 5K (or less) OCIs. I've serviced 2 friend's 2007 TSXs and both used a little oil between services. These cars had far fewer miles than our 2006 TSX (237K). They followed the Maintenance Minder, which I do not.Honda does not specify a service classification or synthetic requirement (at least on my K24 they don’t). This leads me to believe that they are easy on oil.
You're definitely right about the back strain. Took me a couple days of recovery but saved $400. That's what my neighbor paid for his Element. After rotating the motor, I did adjust a couple a final time. I doubt they needed it but after using the feeler gauge so many times you get to know how each feels and I figured it best to make them all as close as possible.When you adjust valves, after adjusting them all, turn the engine at least one revolution and check them all again. The next size up should still be a no-go, the proper size have slight resistance, and the next size down easy to insert. If you have to, adjust again, then repeat turning and checking until all are adjusted properly. This may add a heck of a lot of time to the job and a heck of a lot of strain on your back. But when done it's done right.
Mine doesn't. Link. I should be thinking of replacing the cam, but it's far from a new car, and I can't have the downtime at the moment.Im not replacing the cam either way. Mine looked normal, I guess.
Oh wow, I've never seen one like that.Mine doesn't. Link. I should be thinking of replacing the cam, but it's far from a new car, and I can't have the downtime at the moment.
2003 was apparently not a good year for exhaust cams, I'm not the only one.Oh wow, I've never seen one like that.
One of the best engine Honda ever made....
Mine has seen everything from Castrol to Pennzoil to Mobil 1in 0W20/5W20/5W30/10W30. Microgreen, Denso, Honda, and more regarding filters, and every interval between 5K and 10K miles. I can't actually believe it looked as good as it does, considering I basically have used it as an experiment, driving 75-80% highway miles. I have used MMO, LM MoS2, Seafoam, HPL Engine Cleaner 30, and soon will use BG EPR in it.One of the best engine Honda ever made....
They are easy on oil, but only the earliest I imagine did not specify at least semi synthetic. Our 2005 calls for 5W20 semi synthetic, which I read as PUP or Castrol Edge 0W20 in 2025.Honda does not specify a service classification or synthetic requirement (at least on my K24 they don’t). This leads me to believe that they are easy on oil.
I would say the best, with the J Series a not so close second.One of the best engine Honda ever made....
The Sierra NV mtn ranges still have snow on top here in July. I believe the peaks on I-80 are around 12k ftDid you see what the rest looked like? The car was completly rust free other than that rear areas.
Out local Honda dealer had at least 30 CR-Vs which Honda bought back due to this specific rust area.
I have a buddy who had 2 CR-Vs, his wife's and his. They both were bought back. They bought a new CR-V with the money.
I'm jealous of those who are ignorant of what salt and 6 months of snow do to a vehicle. In fact we still have some snow on the ground, but it's in the mid 40s today.
