I think I'm going to get a second pair of Rhino Ramps for the rear wheels for changing oil on the wife's Kia Seltos. I've changed the oil twice now and made a mess both times. The Seltos has a large tray underneath but it has cutouts for the drain plug and the oil filter, unlike my Sorento which just has a giant tray with 17 bolts holding it up. The problem with the Seltos is that the drain hole on the oil pan faces toward the front of the car. So while most of the oil stream shoots forward, a small amount runs back along the length of the pan since the pan is tilted front to back because of the ramps. Also as the stream slows down, then more of it is directed along the oil pan and ends up on the underside tray. When the low spots on the tray fill up it then runs off onto whatever. I could remove the underside tray but I don't feel like doing that. So I'm thinking that a second pair of ramps for the rear wheels will have the car in a level situation, assuming that I'm starting out of fairly level ground. If the car is level then the slow stream of oil should drop down instead of running toward the back of the car along the pan.
Make sense? Anyone ever done that?
