Originally Posted By: Ducman
Except dexos was always intended by GM to be a global spec.
For sure; at least, the marketing material stated as much, and I have no reason to disbelieve them. Of course, they always did have to consider market inertia, not to mention different emissions regulations, different fuels, and different fuel economy regimes.
When it comes down to it, given CAFE regulations, combined with the state of fuel in North America and us trying to lengthen OCIs, a dexos2 oil isn't quite as optimal. Yes, I'm the first guy to say it isn't all CAFE's fault that we run thinner oils, but CAFE is far from simply a passing consideration.
Getting Europeans or Aussies to side on a 0w-20 dexos1 oil might be problematic. I'm sure enough GM fans in North America are nervous enough about that. At least when dexos1 came out here, it did provide some continuity in some product lines.
To be sure, if I had a new GM vehicle right now and I were given the option of a dexos1 or dexos2 oil as interchangeable, as it stands, I'd have to choose the dexos1 option. Basically, Pennzoil Platinum 5w-30 dexos1 in a 5 L jug on special at just over $30 is a lot more economical than buying any of the dexos2/C3 options I've seen, which are only available in single litres, so far. In other countries, things could very well be reversed.
GM certainly had a vision, and I applaud that idea. But, reality often gets in the way.
I had higher hopes for dexos1, with it being more like the LL-01 and other European specs. You buy dexos1, you've got the right oil for your GM gasser, period. That worked fine as long as 5w-30 was the only dexos1 oil. With 5w-20 and 0w-20 tossed in (GM says 0w-20 now for all the 20 grade applications), that's a backwards move. The logo is still there, but people have to pay attention to viscosity again.
Here on BITOG, we tell every BMW owner that the LL-01 oils are all interchangeable and to forget the SAE grade on the bottle. With GM, you have to look for the dexos1 logo, but then pay attention to SAE grade all over again.
