I can understand the confusion but it works like this...
MB 229.XX denotes MB's PCMO specs. MB 228.XX is for HDDO. However MB 229.XX oils have to be tested for BOTH gasoline and diesel performance.
MB 229.51 is a low SAPs oil designed to protect against DPF blockage on a diesel passenger car (hence its low TBN). However the same oil on a gasoline powered car might see that low TBN quickly depleted so you would be better off using a higher TBN 229.5 oil. So what QP said is quite correct.
