Originally Posted by RDY4WAR
Originally Posted by Linctex
Originally Posted by Talent_Keyhole
....they leave 10-20% of the used oil in the engine for another full OCI. So this percentage will now have twice the hours and miles, which contaminates the new oil, and exposes the engine to higher, wear contaminents, sludge, and combustion byproducts.. Complete a full flush between oil changes.
Sir, I do NOT agree with this statement at all.
It is merely hearsay and there isn't any proof to support your claims.
The risk of leaving 10%-20% of the "old" oil in your engine each oil change is ZERO.
There is NOTHING that occurs that causes the calamity you claim that it does.
You always leave a small amount (0.5-0.75 qt) of oil behind in the engine with each oil change. It's puddled up in the head(s), crankshaft bores, etc... and you could leave your car to sit for 10 days to drain and it won't come out.
You'll often see two specs for oil capacity of an engine. New fill and service fill, with the new fill being 0.5-1.0 qt more than the service.
That said, this is not a concern whatsoever. Pouring in new oil for a quick flush is a waste of oil and you still won't get all of the old oil out.
As far as the color of the oil goes, black oil is not an absolute indication of cleaning. Oil turns black from oxidation. Contaminants act as catalysts for oxidation, but the oil will still oxidize without contaminants from normal heat cycling. It's very possible that the bottle of flush solvents is acting on the oil the same way as a sudden, massive dump of fuel dilution causing very rapid oxidation of the oil. It turns black very quickly, you think it's working, the flush company makes their profit, and everybody is happy... except the engine.
Also note that some ashless dispersants turn dark from UV exposure (from combustion events) making the oil appear black when it's actually not.
Oil may be puddled up in the crevices in the head or other flat areas, but the oil pump remains full, the oil galley leading up to the filter is mostly full, depending on the filter design and location, If you have a cartridge filter that is services from the top, several ounces remain in the housing along the main oil galley. Oil galleys remain full leading to the crankshaft. The oil galleys remain full inside the head. In my 2.4L with dual cams and VVT, there are three galleys with restrictor orrifice between the block and head. This is to keep the 16 hydraulic lifters, 10 cam journals, two cams, 2 VVT solenoids and the 2 camshaft actuators fully supplied with oil at every start up. I know because I have examined the head and engine up close while disasembled and noted the size of these galleys. They are large and are of significant volume. The days of 2-valve, rock arm style heads and single cam engines are over.
Who says this is not a concern? I have the VOA and UOA, particle counts, showing significant particulate contamination, 5x increase in wear metals, viscosity loss, TBN loss, and increase in oxidation caused by the residual oil after operating for 15 minutes.
Waste of money, hardly. Completing this $15, five quart flushing using API rated oil, will remove 99%, a second flush will rid the engine of 99.9%. Simple math. Use the flushed oil in your garden and yard equipment or if you have a old beater of grocery getter, or farm truck, use the oil in those. Don't spend $30+ on a new car just to repeatedly leave contaminated oil in the engine.
