- Joined
- Jul 11, 2014
- Messages
- 4,118
Address all other maintenance. Start with plugs, thermostat, cap, air filter, timing belt kit, rad cap, PCV valve, coolant, transmission fluid, ........
Synthetic oil every 3k-5k/6months is all you need. Vary the brand. If there is oil consumption, go a little thicker. Check oil level frequently and top off as needed to keep it full. There is no need for a flush when changing brands or types of oil.
Pull off a valve cover and post pictures.
I've seen lots of products work. So, there isn't only one. Know the amount of crud prior to any cleaners.
