Best way to clean valves on this direct injection engine?
2019 Chevy Malibu
'm wondering. I thought chevron techron would be enough to clean engine out but since the engine is DI it seems that isn't the case.
Is there a chemical I can use to clean the intake valves out with? And how would I go about doing so without removing the intake?
It seems that most that don't clean them never have noticeable problems. With that being said, try Valvoline Restore and Protect and take it on a highway drive. Keep rpms at 4k for about 20 minutes. Worth a shot.
I don’t think that would do a thing to the valves. Maybe some oil vapors from the PCV will get on them. Won’t hurt anything to try though.
What ls1mike said not withstanding, DAP did a couple of videos on YT on this (on VWs) and the basic conclusion was manual cleaning.
You're probably right. I'd be curious to see if it worked. Based on the VW study and fact that Valvoline Restore and Protect seems to clean whatever it comes in contact with, I do wonder if it would slowly work.
I have had 2 cars with DI engines. First car went to 250,000 miles, I bought it with 120,000 miles on it. Second car bought with 85,000 miles on it, now has 155,000 miles. They both run fine with no cleaning of the intake valves. IMO the best way to clean the valves is to not do it.
I think a better take is "clean the intake valves on a DI engine when required, or necessary".
Generally that will be when you notice unexplained gas mileage drop, a check engine light or other anomaly that would dictate additional investigation that determines intake valve deposits are the cause.
Best way to avoid issues is to do the work and take the intake off. I used CRC Intake Valve Cleaner and a wire brush to clean the valves on my Focus ST, and I can tell you that just spraying it into the intake of a running engine is not going to do anything. That stuff has to soak and turn the carbon into tar, then into liquefied tar, so it can be vacuumed out. I made multiple passes on each cylinder..... Flood the port, let it soak, scrub, vacuum.
Something additional to note is that if the CRC does actually work on the running engine and chunks of that carbon break loose, your turbo could suffer. Best plan is to take the carbon out through the intake, not send it through the exhaust.
Nothing sprays on the valves to begin with which is why some of them carbon up.
How is this car actually used? Stop and go / short trips seems to be the hardest on DI.
Walnut blast is the safest since the carbon comes out dry with the walnut shells. You can gear up to do it yourself, or just pay the dealer when / if it needs it ever.
It's a lot of short drives. In live 15 minutes from work, however I do make it a point to drive about 50 miles one trip on every fresh tank.
