Patman
Staff member
- Messages
- 21,989
- Location
- Oakville, Ontario
Al the main reason LT1 owners like to put in a colder thermostat is that these engines run 10.5 to 1 compression and a pretty aggressive spark advance curve, so if you aren't running 94 octane gas, you'll often get power robbing spark retard in the hot summertime. Going with a colder thermostat lessens or eliminates this knock retard, so you end up retaining more of your horsepower.
I still run the stock thermostat in my LT1, because it's my daily driver and I don't feel like swapping thermostats everytime the seasons change. I always let my car cool down at the dragstrip when I'm going for a new best ET, so the coolant temps are always very low to start out on these runs anyways, so I wouldn't see any benefit in a case like that.
