I recently got a 2015 Ram 1500 with the Ecodiesel.
I’ve read extensively and watched numerous You Tube videos on them.
My engine has 102,000mi and is running well. However, at 16mi since a dealership oil change the oil is somewhat “sooty”.
I plan to replace the engine oil in the next few days and want to give the crankcase a good flush.
Oil will be either Mobil 1 or Pennzoil Platinum 5w40 per Chryslers recommendation.
Would a pint of Marvels Mystery Oil on top of fresh fill for 25mi and drain work? I m suspicious that it might have some sludge buildup which can lead to oil journal blockage causing bearing failure…
I bought it with a 24mo extended drive train warranty. Hoping I won’t need it…
If not Marvels, then what?
