An industrious Sienna owner could take inspiration from or adapt GT3 brake ducts.
www.suncoastparts.com
GT3 Brake Duct Spoilers
Check out the deal on GT3 Brake Duct Spoilers at Suncoast Porsche Parts & Accessories
I have actually used Yellow Stuff alot. They work from cold in +5 degrees C. Never tested them in colder. So cold bite is good enough to get them road legal in Europe.
IME, the factory Toyota advics rotors are extremely high quality and much better quality than any of the aftermarket rotors. They are also priced very fairly.Sources for quality rotors - don't have many choices for high quality in Canada. Was surprised to hear some criticism of Centric, which I thought were alright. Will keep looking.
@edyvw - I haven't been able to find a source I can use for Pagid pads for Sienna anywhere.... I'd be interested in some more info on their pad formula. And if they make high-carbon rotors for Sienna. I have Pagid two piece high carbon rotors on my 535 right now (might be Pagid pads too) and I've been quite happy (happier than factory). I'd absolutely consider trying "Euro OEM" brands on the Sienna, but would like first hand feedback.
Have you noticed any differences between the Toyota/Lexus OE rotors made by Advics vs Advics branded rotors?IME, the factory Toyota advics rotors are extremely high quality and much better quality than any of the aftermarket rotors. They are also priced very fairly.
In fact, Toyota/Lexus is the only brand I will purchase OE rotors for (whenever possible).
I don’t think Pagid makes rotors for Sienna and all their rotors are high carbon.So, I've heard a couple of thoughts here that I'd like to summarize, perhaps challenge, and maybe eek out just a little more conversation.
The factory design is fine - it's "fine", but really not great. On my German cars I'm usually an OE guy but here I think I can do better, which means some aftermarket parts but performance is the key while still maintaining daily driving safety (e.g. cold performance) and fit (e.g. pads don't rattle around in the calipers because of poor tolerances)
Yellowstuff is for racers - I have heard in the meantime that Yellowstuff is different between "cars" and "truck and SUV". That means that Sienna "Yellowstuff" might not be the same as Miata or GTI "Yellowstuff" in terms of formulation and performance. There are a lot of different members here with a lot of different cars - I'm quite interested in minivan Yellowstuff just as a datapoint. Thanks to those pointing out other good options like R4S. I don't have a place in Canada to purchase yet but working on it.
Are Brembo Xtra, Ferodo DS Performance and PFC Z-rated easily available in Canada?
Craig, did you check that?
Craig what about Raybestos element 3 pads and rotors? I've used them on my Caravan and they are working well. You can get them shipped to Canada from Rockauto. Shipping was about $60 but I added a few other things to the order.
Good in theory but having just had to replace front rotors and pads on a very gently driven 2019 RX350 with 24k miles on it I'm not as confident about Toyota's choice of brakes.Toyota designed it for 7 people and their stuff in it. OEM pads and rotors are perfectly fine for it. I always thought people who buy EBC pads are just boy racers who think the colors, yellow red green are cool and are willing to pay double for them.
That is probably longer than what aftermarket will last you. I've seen aftermarket pads and rotors last 10-15k on the vans/suv's before developing pulsation. Just had a RX350 with terrible pulsation with Centric Pads and rotors after 10K.Good in theory but having just had to replace front rotors and pads on a very gently driven 2019 RX350 with 24k miles on it I'm not as confident about Toyota's choice of brakes.
Advics makes their rotors. Pads can be Advics, NBK or Akebono (rarely). Advics was OE for the pads in that application and they also have a revised compound for shudder issues. The revised pads have a different part #.OK so Toyota OE is "Advics"? I have seen that brand for sale somewhere. FWIW, the local dealer is a place I've priced. Front rotors have been backordered for 2 months with no confirmed end in sight.
I have only used the Advics branded rotors once and they looked identical.Have you noticed any differences between the Toyota/Lexus OE rotors made by Advics vs Advics branded rotors?
Agreed with all of the above. When our 2018 Sienna had 12k miles the front rotors were vibrating badly. The rotors were also completely rusted after about a year. The replacement rotors were also from Toyota and did the same thing. I finally got tired of it and went aftermarket. I'm not sure what Toyota used for OEM brakes on these vans, but they are garbage. It doesn't help that the rear brakes look like they were designed for a small car.It is absolute garbage. Their rotors will start to vibrate after any aggressive use. It is absolute garbage on Land Cruiser Prado I have in Europe (maybe understatement actually) and EBC definitely resolved the issue with vibrating rotors. Right now on Sienna, I have Raybestos Element3 and Pagid pads, and it is holding fine.
My SIenna is some 4,600-4,700lbs. The front rotor has less contact surface than the rotor on my 328 which is a 3,500lbs vehicle.
It appears that the rotors are like 1" bigger than the camry.Agreed with all of the above. When our 2018 Sienna had 12k miles the front rotors were vibrating badly. The rotors were also completely rusted after about a year. The replacement rotors were also from Toyota and did the same thing. I finally got tired of it and went aftermarket. I'm not sure what Toyota used for OEM brakes on these vans, but they are garbage. It doesn't help that the rear brakes look like they were designed for a small car.
Rotors look big. But hub is also big. Contact surface is actually really small considering size of the vehicle. If you look design of the front pad you can actually see how small the rotor is.It appears that the rotors are like 1" bigger than the camry.
It is front heavy vehicle, but my wife’s Tiguan, also front heavy vehicle, has bigger rear pads and packs some 1,100lbs less. Front is also larger.Agreed with all of the above. When our 2018 Sienna had 12k miles the front rotors were vibrating badly. The rotors were also completely rusted after about a year. The replacement rotors were also from Toyota and did the same thing. I finally got tired of it and went aftermarket. I'm not sure what Toyota used for OEM brakes on these vans, but they are garbage. It doesn't help that the rear brakes look like they were designed for a small car.
