I'm looking for a larger oil filter for my wife's car. It currently uses a Wix 51348 (or equivalent) oil filter. I'd like to use one that's a little larger and maybe an inch longer.
What's the easiest way to cross-reference to the same spec filter, except a little bigger and longer?
Thanks,
Al
51348 specs:
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-06), Various GM (85-05), Lexus (90-06), Saab (67-06), Saturn (91-01), Suzuki (86-02), Toyota (88-06), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Thanks,
Al
51348 specs:
Part Number: 51348
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Gasket Diameters
