This is a 1,000 mile drain on an 80k mile ea888 running an e50 blend. Oil looked totally normal upon initial drain, but after sitting and spinning it around you see some minor swirling only when shining a shop light into the drain pan. Can’t say I’ve ever moved the old oil around this much before to say I’ve seen it or not in the past. UOA’s usually good and no meaningful metal in filter. Engine sounds great.
Edit: oil used in engine is LiquiMoly Leichtlauf 5w40. Maybe it’s additives?
