I'm new here, and couldn't find a rule stating that I couldn't go ahead and post. If I am in error, please let me know and I will remove at once.
I've decided that I can't stand the onset of an intermittent lifter tick and the hard to reach/dirty to change oil filter on my 2014 RAM 1500's 5.7L Hemi so it's getting a remote mount filter. I purchased the following items to do that job:
This filter pad adapter:
https://derale.com/products/filtrat...oller-with-thread-in-probe-25-amp-detail
This dual filter mount:
https://shop.perma-cool.com/61221-Comp-Dual-Filter-Mount-10AN-SAE-Ports-3-4-16-Thread-61221.htm
...and a bunch of -10an hose and straight fittings. Those hoses will have no less than 5" radius bends and will be no where near anything that hurt them. The dual filter mount will be bolted directly to the frame rail in front of the engine on the passenger side where I've got 10" of space.
So about the filters...
The stock Mopar filter (only one that won't leak; you wouldn't believe how ridiculous the dealer was) is MO-899 and has the following specs:
part number bypass flow anti drainback valve nominal micron rating
MO-899 (stock) 16psi 9-11gpm yes bout a half inch.
I have considered many different options, but as I have a huge amount of space, why not use a giant filter with excellent flow and super fine filtering? What about dual Baldwin 7311-MPGs? The specs are nowhere near the stock bypass, but I'll be running two of them off of -10an hoses within 2ft the original mount point, so flow and pressure loss shouldn't be an issue, right?
Here are the Baldwin specs that I *think* are correct, but they are stolen from overdrivesteve here (https://forums.ihpartsamerica.com/showthread.php?t=4022&page=2):
Part number bypass flow anti drainback valve nominal micron rating
Baldwin 7311-MPG 8psi 10gpm @ 2psi yes 8 nominal, 20 absolute
Thank you for reading this far.
Based on what I've read the Baldwin 7311-MPG seems like an awesome filter for a huge engine, but this is a little Ram gas burner pumping 5w-20. How can I blow this thing up?
