Originally Posted By: Virtus_Probi
Originally Posted By: Ducked
Originally Posted By: Char Baby
The also have IIRC, 7 virtual gear/feel = fake shifts as do the other MFGs.
That seems a bit weird.
If I understand you correctly, they are simulating what was an imperfection in a "classic" GM style auto box because that's what people are used to?
I can set my car in I, S, and S# modes, and also have the choice between auto or paddle shifting settings in each mode.
For either setting, the car will pretend to have 8 speeds in S# mode.
If I paddle shift, the car pretends to have 6 speeds in I and S mode.
I only paddle shift in tough winter conditions because it is too slow for sporty driving. The downshift paddle shifter still comes in handy in the auto settings because I can stab at it when I'm going to get on it and jump up in RPMs quickly...the car was a lot less fun before somebody clued me in to this function. I actually put extenders on the rather small paddles since I use that trick so much, although I probably only really needed one.
I generally use auto S mode unless I'm driving in bad weather and stick with I...S# mode generally feels too jumpy and my mileage is pretty bad using it. In auto S# mode, upshifts are delayed to keep revs higher...some people say it is great for aggressive driving in hills with lots of tight turns, but it mostly just drives me crazy.
I believe this was all adjusted for the 2017 FXT and I'm not sure how things work now.
Thanks for the explanation. Whole new world.
I've only had one autobox and never really got to like it. Currently, if I don't like the shift pattern, I can usually find the problem in the mirror.
