Well I mixed oils thinking I was making things better. I am dyno testing my engine and after break in which went great, I changed the oil and filter. I used 3 qts Mobil 1 Euro 0W40 and 3 qts Quaker State All Mileage 5W30 with Microguard Select VAFI filter. We noticed the oil pressure would drop a few psi over a certain rpm range, and got worse with higher oil temps. Scratched our heads to figure out why and the only thing we could come up with was the blended oil (and maybe filter). So drained the oil and filled with 6 qts Mobil 1 Euro 0W40 and changed the filter. Problem solved! Pressure now was steadily rising over the run. The attached plot was worst case we saw. The after is also shown and looks like it's supposed to.
