I do appreciate the posting. I also posted something about weird oil pressure. It takes time to cover all the questions the others have. Best of luck to the OP.
Technically there's some of the factory fill in there too, if you want to get technical.Lol at thinking every drop of oil is removed from the system with one or even a few oil changes. I probably have remnants of 20 different oils left in my engine.
While that is technically true, once you have run the same oil for 4 or 5 intervals in a row there’s probably only 1 or 2% residual left of the different oil that was in there before. So it’s really not a Frankenstein-Brew at all.Unless one ran the same exact oil from the day the factory fill was dumped there’s always residual from the previous fill and no pouring that leftover quart through from the last oil change isn’t changing molecular chemistry lol. So unless we’re religious and brand loyal there’s a little bit of a Franken-Brew in all of us. I’m guilty there I go from Kirkland - Supertech - Mobil 1 - Castrol - Pennzoil - NAPA full synthetic. Even a Qt of O’Reilly house brew synthetic when I was a Qt shy for an oil change.
I did some studies with Nissan about 10 years ago where they had problems small engine SUV's a Pickups driving several times a week up and down the mountains from 600 ft above sea level to 12,000 ft before coming down to the city at 8500 ft. These were driven at high rpm for extended periods of time and built high temps on the climbs.I used 3 qts Mobil 1 Euro 0W40 and 3 qts Quaker State All Mileage 5W30 with Microguard Select VAFI filter. We noticed the oil pressure would drop a few psi over a certain rpm range, and got worse with higher oil temps.
Yes, but why would it drop and come back?
Probably a combination of very ideal usage (highway miles) and using very high quality oils. Hard to beat VW 502 and 504.My lowly 2012 Transit Connect lived its life on frankenbrews of leftovers from my Audis and VWs and was well over 200k miles when I sold it. It had the basic 2.0 Duratec engine and saw 200 to 400 miles a day fully loaded with mostly highway miles to get to very remote rough last mile destinations. It never used oil and typically saw 7,500 to 10k oci.
I never thought about incompatibility of mixing oils like I did, but it was always pretty much top end euro oils that the VAG engines required ranging from VW 502, 504 and 508 specs so I doubt there would be much incompatibility among them.
Not a surprise.Well I can confirm, it's not the mixing of oils that is at issue. So mix away!
So you were able to reproduce the issue?Well I can confirm, it's not the mixing of oils that is at issue. So mix away!
No but I was able to solve it but taking a quart of oil out.So you were able to reproduce the issue?
It’s a miracle.No but I was able to solve it but taking a quart of oil out.
My compressor has HPL recip life. My mower and PW get VR1 20w-50 synthetic.I use leftovers for the mower or pressure washer or something that the sump is small enough that not a lot is needed. If it's a really small amount, I'll use it for a GP lube.
My compressor has Mobil 1 0W-40 in it, my push mower currently has Mobil 1 0W-40 in it and my pressure washer has Redline 5W-30 in it I think? My generator has Pennzoil Ultra Euro 5W-40 in it. The Redline and Pennzoil were both spare quarts I had kicking around, so if you've got OPE, that would be a good use for that 5W-40.
Appreciate the answer. But the oil pan is a 6 quart pan. I added a full-length close-fitting louvered windage screen. I had 6 quarts in it, the required amount. I was not expecting to have to drain oil out.It’s a miracle.
So it was indeed foaming, but due to windage from the sounds of things.No but I was able to solve it but taking a quart of oil out.
At least it’s resolved, and now we all know it wasn’t due to mixing oils.Appreciate the smart ass answer. But the oil pan is a 6 quart pan. I added a full-length close-fitting louvered windage screen. I had 6 quarts in it, the required amount. I was not expecting to have to drain oil out.
Correct. I think the windage screen was not correct for this particular set upSo it was indeed foaming, but due to windage from the sounds of things.
