I'm new here and was hoping to find some answers here. The subject is a high performance SBC with a high volume high pressure oil pump (anti-cav). Car has a Canton 15-240T pan which is all baffled and has a windage tray +7qrt capacity, it has a B&M HI TEK oil cooler, remote oil filter and Canton Accusump.
I was running a 10W40 halfsynt oil at first in this new engine. Oil pressures cold were up to the bypass setting of 75 when running, 60 on cold idle. During warm up, I was seeing idle oil pressure around 30-35 psi. The issue was that in this high rpm engine I'm seeing the oil pressure drop at speeds over 5000 rpm. I have tried both lowering oil level and more oil in the pan, but it didn't help anything. I changed from the AC Delco PF2 filter to a Motorsports FL1A filter which didn't help either.
Last thing I did was changing to a Valvoline synth. 5W30 and it seemed to improve the idle oil pressure to my surprise, getting around 40 hot. The high rpm oil pressure dropped only 5 psi where it previously dropped 15-20 psi, and it seemed to stay there. Haven't run her up to her rpm limit though.
I was thinking about cavitation somehow, but I'm not sure. Any ideas ? Is there a solution to this ?
Thanks
Yves
Thanks
Yves
