All ATF that is pumped comes from the pan. But, the cooler does not see all the pumped ATF. Much is used and wasted back to the pan. The cooler gets surplus flow. Also, the ATF pickup isn't touching the bottom of the pan. So, there is even more old ATF in your transmission then you want to believe when doing a stand alone cooler line flush without dropping the pan or pulling the drainplug.
Because the pan has old/new ATF mixing, and because the TC has old/new ATF mixing, it is more beneficial to start with new fluid somewhere, otherwise you'll waste gallons trying to flush out old fluid that is constantly mixing with new fluid in multiple places. This is why the pan drop(or drainplug drain/refill) should be done prior to starting a cooler line exchange.
Its like making coffee and grabbing the cocoa by mistake.
Do you dump out the full cup of cocoa and start over(TC drainplug and pan drop) which is super effective, or do you dump out half the cocoa and constantly overfill the cup with coffee until you are satisfied that the cocoa is gone(effective but you wasted a couple cups of coffee), or do you just overfill that full cup of cocoa with coffee until you are satisfied that enough of the cocoa is gone(not too effective and pots coffee wasted)?
Also, how much ATF did you remove or actually use? If you are not pumping plenty of ATF through the cooler line, you are just wasting time and should just use the drainplug. 9 quarts(typical capacity) of dirty ATF(cocoa) will take plenty of new ATF(coffee) to remove. This is why typical ATF flush machines run 12-20 quarts of ATF.
There is really nothing to understand. You need to waste plenty of fresh ATF to remove old ATF using the cooler line. If you have the means of removing any old ATF without mixing(drainplugs), then do so.
