Arrg. Having to re-type this all again.
Help!
I have part of the fluid drained out but I'm 'stuck' and need to be able to drive it in the morning.
The cooler lines:
One line (call it line 1) goes from the top of the transmission, near the back of it, to the left side of the cooler.
One line (call it line 2) goes from the right side of the cooler to the bottom of the transmission, near the front of it, and right above where the pan mates to it.
Working with line 2, near the cooler, I disconnected the rubber hose portion from the steel hard line portion, and put the ~6" section of rubber hose into a jug. So, from cooler and into jug. I left the hard line section open.
When I ran the engine for no more than 1 second, quite a bit of fluid came out the hard line, making a mess, but none came out the rubber hose. What happened?
Are we sure the fluid returns from the cooler into the pan?
Do I just need to plug the hard line? Did it back pump somehow?
Thanks!
Help!
The cooler lines:
Thanks!
