Originally Posted By: Corvette Owner
I did a google and it looks like only 2 psi pressure drop can be attributed to the oil filter. This is relatively insignificant when compared to the 40-60 psi of a running engine. I think this is the point he was making.
So what flow conditions was this 2 psi pressure drop across the filter associated with? If I had to guess, I'd say when the oil was hot and thin. Also, what filter was this for. I'm sure there must be some variance between filter resistance, but maybe it's not enough to be concerned about.
Seems like these discussions keep going round in circles to some degree because there are rarely qualifiers put on general statements made.
The filter's pressure drop is dependent on many factors that dynamically change in the oiling system - namely, the oil viscosity and the oil pump's flow rate (which changes with engine RPM). It's a very dynamic system. Obviously, the highest filter PSID will occur at the highest flow rate with the highest oil viscosity (ie, redline with oil at -20 deg F for example). Of course, the highest PSID any filter could achieve is equal to it's bypass valve setting.
I guess one way of looking at the split of filter vs. engine pressure drop would be by looking at the filter vs. engine PSID ratio. If a filter drops 2 psi while the engine oil pressure is say reading 50 psi, then the ratio PSID ratio is 2:50 (filter:engine).
So if the max relief pressure of the oil pump is set to say 90 psi, then one would expect the PSID across the filter just before the pump goes into relief mode to be (90/50) x 2 = 3.6 psi.
