Dodge Hellcat Oil - Valvoline, Castrol or Mobil 1 ??
ohio
Need oil for my 2017 Hellcat
Chrysler recommends MS 12633 Pennzoil Ultra Platinum 0w-40
What I can find locally
Mobil 1 Euro 5w-40 (does not meet MS12633)
Castrol Edge Euro 5w-40
Valvoline Euro 5w-40
The Castrol is made from base III stock.
Does anyone know what the Valvoline base is ?
All the oils you listed are majority group 3 and will perform similarly if the approvals are the same.
If you want majority group 4/5 you’ll have to look elsewhere. And spend a bit more $.
The Valvoline oil is the same as the rest and that's ok as it has to meet certifications on performance of which is mb 229.51, Porsche a40, and bmw ll-01 which quaker state 5w-40 also does and it's what I use in my 6.2 gm. Doesn't really matter if it doesn't meet whatever that ms spec is, those 3 are great. Pennzoil Ultra Platinum 0w-40 isn't spectacular pao oil or anything.
In this particular order:
  1. @High Performance Lubricants Super Car 0W-40
    • PAO + AN + POE + Other Secret Esters + Infineum Additive Package + Additional Top Treatment with MoDTC and Ca + Mg based detergents
  2. Mobil 1 0W-40
    • PAO + GTL + AN + Infineum Additive Package
  3. Quaker State Euro 5W-40
    • GTL + Group I Additive Package Carrier + Infineum Additive Package
  4. Pennzoil Platinum Euro 0W-40
Castrol's 5W-40 base oil is Group III + HVHI, and Castrol 0W-40 is Group III + HVHI + PAO. Valvoline Euro 5W-40 is Group III + HVHI, and Valvoline 0W-40 is Group III + HVHI + PAO. It's nearly impossible to blend a 0W-40 without PAO.
Ultimately, all these will perform similarly. However, with HPL, you'll be able to go longer on the same fill while keeping your engine spotless. Mobil 1 would be my next choice since they are a leader in formulating and blending some of the best lubricants.
It's just a recommendation based on my personal preferences. I have used all the oils I listed except for Pennzoil Platinum Euro 0W-40, and Valvoline 0W-40 & 5W-40.
I’m aligned with Invisible and Overkill.
You might also consider the Auto Zone special combo of 5-quarts of Mobil 1 ESPx3 0W-40 and an Oil Filter. You may double up, and the corvette crowd retuns the filter so they can just get the oil at ~45% off.
Lastly, Amsoil Signature Series 0W-40 or Amsoil Euro 0W-40 are worthy of consideration, especially if you’re signed up as a preferred customer.
FYI. MS 12633 is now called MS A0921 for whatever reason on the PUP SRT 0W-40 bottles.
Any CDJR dealer likely carries it if you decide to go that route. I still buy it from the dealer for their receipts as I still have about 10 months left on my Hellcat’s extended powertrain warranty. After that, I’ll likely switch to one of the ones mentioned above.
5.3L Hellcat
Schaeffer's 9000 ,0w-40 has the MS 12633 approvals, think outside of the box, its a great oil for your vehicle, though 0w-40 Pennzoil Ultra is also the factory recommended oil and would likely the oil I would use over the usual ones you mentioned, . depends on how hard you drive it, good filtration is to be considered too.
The Dodge Hellcat has been in production since 2015. At the time Dodge specified Pennzoil Ultra Platinum 0w40. So, how did it turn out. Were the engines ‘sploding? A quick look at the Hellcat forum indicates very few people complained about the engine. Although I can’t prove it I’ll bet most people ran Pennzoil Ultra Platium 0w40 until at least the warranty ran out.
It's recommended for the application, just like AMSOIL Signature Series 0w40, neither are approved by FCA/Stellantis.
The original SRT oil was Mobil 1 0W-40 Euro. When Fiat merged with Chrysler, they brought their Pennzoil contract with them and immediately terminated the agreement with Mobil, who had the factory and service fill contracts for Chrysler.
The Pennzoil "SRT" 0W-40 was cooked up in short order to replace it and is generally rather unremarkable, basically being a vanilla API SN RC additive package blended as a 0W-40 with considerably higher Noack than the Euro oil it replaced.
Now, the SRT engines have roller lifters, unlike many of the applications where the A3/B4, A40, LL-01...etc oils like Mobil 1 0W-40 are spec'd, which have sliding followers, like the S62 in my former M5. This may be why they went with a lower (RC-level) phosphorous additive package, which is what is spec'd for its more pedestrian 5.7L sibling. That said, that doesn't mean that areas like piston skirts, rocker tips, rings, pushrod cups, lifter bodies, timing chain...etc may not benefit from the higher levels of AW additives found in the Euro options.
I used SuperTech 10w-40 blend and Pennzoil Euro 5w-40 for 5k miles in the wife's 4Runner and had both analyzed. SuperTech edged out the Pennzoil ever so slightly, Yea, surprised me too! :unsure:
2010 Viper was Mobil 1.
2011 Viper was Pennz.
The change to SOPUS was made as Mopar was switching from SM to SN formulations as I understand it.
This was December 12th, 2010 at my dealer, based on the date on the photo:
2011, Mobil 1 0W-40 was SN:
Here's the thread about my dealer changing over, 2 years later in 2013:
The service manager at the time wasn't thrilled about the mandated changeover.
I'm not sure if it was a hard date, as to when they changed over? But I know my dealer had to make the change at the end of 2013 there, prior to that, they were a full Mobil shop, with Mobil 1 0W-40 as the service fill for all SRT vehicles.
  • Like
Reactions: 4wd
