Yes, you ONLY want to use one labeled as Mass Air Flow Sensor Cleaner.I've been thinking about cleaning mine. Is there a special cleaner to use? I've heard that some types of cleaners could be harmful.
Where did you hear that? Here perhaps?I've heard that some types of cleaners could be harmful.
Seriously, some electric cleaners leave a coating (lube or anti-corrosion) which effects MAF sensors' operation.
Thank you.Yes, you ONLY want to use one labeled as Mass Air Flow Sensor Cleaner.
CRC makes a good one that most use.
What was in the flammable propellant? It could leave a residue as well - no?electrical contact cleaner uses a flammable propellant
Hmmm ... it might be useful to see if the Camry has that feature. Right now I have no idle issues, the mileage is very good, and the engine runs smoothly throughout the range. Might not even need to clean it.I haven't had to clean a MAF in 20 years. I think most of the current ones are self-cleaning (heated). If I'd notice a loss of gas mileage or other performance problem over time I'd give cleaning the MAF a try.
I clean mine when I change my air filter.
Do you have a set schedule or have you never done it?
MAF sensors are a hot wire that cools with airflow, providing different resistance values as it warms and cools. It's not that much heat, and it's cooled real-time by the airflow.I haven't had to clean a MAF in 20 years. I think most of the current ones are self-cleaning (heated). If I'd notice a loss of gas mileage or other performance problem over time I'd give cleaning the MAF a try.
Where do you guys get this stuff?MAF sensors are a hot wire that cools with airflow, providing different resistance values as it warms and cools. It's not that much heat, and it's cooled real-time by the airflow.
There is no self-cleaning MAF sensor in existence. With any modern air filtration design, the MAF sensor doesn't need to be cleaned, unless damaged or tampered with such as a repair was done, or rodent damage, etc.
Mass air flow sensors are tasked with measuring the amount of air entering the engine via the intake. This mass air flow sensor is known as a hot film sensor which will suffer performance deterioration over time. The sensor is designed to be self cleaning. A faulty or non functioning mass air flow sensor will cause a check engine light and in some cases cause a limp mode. The best way to diagnose a faulty mass air flow sensor is to disconnect it and see if engine idle or performance improves.
My oven is designed to be self cleaning, too. Doesn't do a great job with plastic.Where do you guys get this stuff?
This one and many others are in fact self cleaning.
BMW Mass Air Flow Sensor - Bosch 13627602038
BMW Mass Air Flow Sensor - Bosch 13627602038www.fcpeuro.com
