“Clean your MAF!” - everyone
Atlanta
Why does it seem that everyone always says “clean your MAF” for every problem? Idle issues, stumbling, misfires, low power, etc. you name it. On Facebook auto groups, forum search results, everyone says “clean your MAF” and then the original poster responds with either “it did nothing” or “worked for a little while, the prior issue returned.”
Why do so many people recommend this? Is it just me, or do MAFs rarely even fail? I’ve never had one fail, can’t recall an internet poster saying it worked. Have you seen a MAF cleaning resolve an issue?
Without engine trouble codes giving some kind of pathway one of the easiest things for a DIYer to do is clean the MAF sensor and many times it is as simple as a dirty MAF sensor.
A dirty MAF sensor absolutely can cause idle issues, stumbling, low power, etc. And you should clean your MAF sensor every air filter change.
On some vehicles a dirty/bad MAF sensor can eventually wipe out the transmission due to it raising line pressure.
90% of people trying to DIY car repair and diagnosis of a problem are trying to parts cannon their way around not having access to a scan tool that will tell them if and what codes are set or give them a meaningful datastream. MAF sensors fail all the time, and get dirty often. Cleaning them is cheap, although in my experience once it's coding or causing any kind of noticeable issue it's junk.
100%
Absolutely
in my experience the 2003-2008 Corolla or Matrix and 2000-2005 Celica GTs absolutely benefit from cleaning a dirty MAF sensor, yes codes went away and the car absolutely drove better.
Note: This experience is with 15+ vehicles, not 1 and even with perfect maintenance after 30-40k miles, I would see the MAF get dirty but no codes.
Learning from the experience listed above, I started to clean my MAF sensors in my 2GR-FE applications (have owned 7), there were no codes and it made no difference and the MAF sensors were very clean to begin with, which led me to believe that the air intake pathway is designed better and keeps these MAFs very clean but regardless of this, every 30K miles when I clean the Throttle body, I clean the MAF and PCV valve.
I clean mine every 30K. Same time when I clean the reusable air filters…Dryflow type. This time on the Pilot my wife commented her MPG’s went up 6 mpgs. It’s showing 28.
It's suggested because it's essentially free.
Yes I've seen them cause problems from being dirty.
Yes I've seen one fail -- or at least need to be replaced because cleaning wasn't doing it.
MAF codes were absent in each case.
IME you can sometimes see the "filter" side appear black (or dirty) while the "engine" side is silver. Cleaning takes both sides to silver.
Anyway it's far from a panacea but it's also far from the parts cannon. Also I think frequent cleaning may risk introducing more problems than it solves, so it shouldn't be a regular thing. Every 30k is not unreasonable however.
Had a MAF sensor that failed on an 01 Corolla. Tried cleaning it multiple times with no luck. I got one from a junkyard, swapped it in the parking lot and the drive home was a whole new car.
I always clean my MAFs when I get a new vehicle and periodically through its life just cause as mentioned, it's essentially free.
I had a MAF sensor fail on my old 940 Volvo. Replaced the original Bosch with a Delphi and that soon failed too. Cleaned the original with the proper spray and it has worked ever since. Tossed the Delphi in the trash. My experience running two vehicles with K&N properly cleaned/reoiled filters is that they don't cause MAF codes.
On a 90s ranger cleaning it cured the slight pinging under load. Good gas was used.
The culprit is usually the MAF (hot wire type) being dirty due to lack of air filter maintenance. Dust, dirt, debris, or oil (often from aftermarket air filters) can coat the hot wire, insulating it and preventing it from cooling properly. Therefore, cleaning it can be beneficial. However, there are limits and it does not always work and you end up needing to replace with a new MAF sensor. And if you buy aftermarket MAF sensor, some are skewed right out of the box so be careful.
On the Alfa Romeo forums, replace MAF with Battery, and you get the exact same series of posts.
So many people replace their batteries while chasing after random issues, without actually testing that their battery is actually bad.
What a waste.
If they are having a charging related issue, if its one of the first few years, chances are the culprit is the IBS (Intelligent Battery Sensor).
But, it never throws a code when it fails, so you don't know that suddenly, your battery isn't getting charged above 40%, which is definitely an issue.
Why does it seem that everyone always says “clean your MAF” for every problem? Idle issues, stumbling, misfires, low power, etc.you name it.
Is that really every problem? Dirty enough MAF can cause those particular issues and if someone already knew to clean it every now and then, or knew how to DIY further diagnostic data gathering, then they can ignore the advice and rule that out. Then again...
... yeah. That's not where I would get automotive advice. Even Reddit is better than that. Just sayin', it's real easy to spend someone else's money but in this case, MAF is inexpensive to buy some cleaner and you usually don't need to take off much else to get to it, no crawling around under a vehicle or advanced tech knowledge needed. It's one of the cheapest, easiest things that you "might" be able to rule out if it has a low flow reading but is still providing data. If you don't know why then clean your MAF, then you can state that you already did that. ;)
I'm sometimes guilty of recommending something else too often for similar symptoms - check your LTFT.
I have had it resolve some idle issues. The most dramatic was a 2000 Ford Taurus that my brother bought. On the test drive, you could hear really bad detonation. Urged him to look into it further but he persisted on buying it. He brought over to my house, and I cleaned the sensor. Detonation completely went away! Kind of an extreme example but I do it on all of my vehicles every year or two now.
