The treads on my oil was stripped last year. I had this tapped out. I messed it up when I changed the oil. Without going into details (my brain wasn't working at the time!), the tap sticks out about a 1/8 in. I now have small leak around the hole. When I try to tighten the drain bolt more, I feel the bolt tighten then go loose again. I believe the tap is loose
Can this be fixed again or do I have to replace the oil pan? I am thinking catastrophic engine failure due to the tap falling out and my engine oil taking a dump.
