Originally Posted By: Gimpy1
Originally Posted By: miden851
Originally Posted By: funkymonkey1111
Originally Posted By: dogememe
Whether you go to your local Iffy Lube or do your own oil changs, you're tires don't rotate themselves, so clearly it's not THAT important...
But how much does it really matter? And if you do rotate your tires every oil change and you do it yourself, what's the fastest way?
Personally, I have an electric impact wrench, I have those torque-stick things not to over-torque the lugs, and I have "normal, boring" vehicles that have the same tire and wheel sizes all the way around, but I would literally have to jack up the whole vehicle, put it on jack stands, IDK how to do that safely, easily, and quickly...
every 5000 miles at Costco. Rotate and balance for free with purchase.
the same goes here; plus they use hydrogen on tires, and if there is leak they'll fix it
Ummmm They use Hydrogen???? LOL I think you mean Nitrogen. Which is a sales gimmick. Air is 78% Nitrogen, using "dry nitrogen" will do nothing at all unless you are racing a Formula 1 car where having 1 psi difference between tires is critical.
Yeah I meant to say Nitrogen, LoL; anyway, it works better because the pressure is more stable in tires, so when you have oscillation in the air temperature outside, such as harsh winter or scorching heat; Thus they are not as affected as in ones inflated with air only;
I can attest to that because I use Nitrogen in one of my cars while just air in the other car
