Hi,
I have a 2002 Toyota Corolla with radial tires, and I need to rotate the tires. I have a floor jack, 4 jack stands, and a beam torque wrench.
I plan to rotate back to front, without switching from side to side at all, since the tires are radial.
What's the best way to jack the car to accomplish that? I need the front and rear tires on one side lifted at the same time. Is it even ok to do that? It seems like it might tweak the frame if I were to jack up the front end, put a jack stand on one side, lower front end (leaving one corner of the car on a stand), and then jack up the back end to put a second stand on the same side in the rear. I can only come up with one other option: jack front end, put 2 stands in, then jack the back end and put 2 more stands in... but I've heard that's not really a good idea due to instability.
I'd appreciate any advice!
