Originally Posted By: Audi Junkie
I think in stone-cold it would help w/ starting and start-up wear, especially if the dose is increased.
That's true to a point, you can overdose and cause starting issues, stalling issues, and lack of power. I've played around with the Inverse oiler, and accomplished all those feats. I think running the mix ratio in the gas tank at 400:1 for the winter months is a good idea, and certainly won't cause any of the problems I mentioned above. Too much oil decreases octane unfortunately. I would certainly experiment with increasing the winter dose, its worth the added protection, and you might even be able to run it at 300:1 if the engine doesn't respond negatively.
Just another hobby for the BITOG'ers!
JMO,
Frank D
