Hey everybody I made a threat about torque converter shudder I changed all the fluid in my 92 F150 and it still has the shudder problem. I even use some lube guard shudder fix and I think it helped but it's definitely still a problem it normally only acts up on hills and light acceleration but sometimes it'll act up under light acceleration on flat ground. And I believe it's usually going into third gear but I won't swear to it. Could I just disable the lock up converter it's a twenty-six-year-old truck and I really don't want to replace the transmission if I disable the torque converter lockup and it would work properly I would be fine with it. Any information on this is highly appreciated.
