Did SAE recently double the CCS values?
According to the Lubrizol website, there have been new standards set since Dec. `99 that were not enforced until June `01 regarding the CCS values at temp..
Are oils thicker than they were in 1997?
From a 76 Lubes publication:
"New Cold Cranking Simulator (CCS) viscosity limits for multigrade engine oils, part of
the SAE J300 Engine Oil Viscosity Classification standard, were established back in December 1999. Although not specifically part of API SL/ILSAC GF-3, these new limits are included here because mandatory compliance begins June 2001, and thus applies to all multigrade API SL/ILSAC GF-3 engine oils. The new CCS viscosities are measured at a temperature 5°C lower than previously, and the maximum viscosity limits are essentially
doubled. The reason for this change is that modern passenger car engines start at lower
temperatures and with higher viscosity oils than the engines used to establish the previous
limits."
...Except now GM wants to go back to the old Cold Crank Simulator limits.
Ken
The one thing I've wondered, is that if an SL formula 10w30 would actually be classified as a 5w30 under the old SJ rating system?
So are today's 5-30's the same as last year's 10-30's?? ie. we're getting more protection from a 5-30? That may make 5-20's more acceptable.
quote:
I think it's more like the other way around, that the latest 10w30s are probably more like the old 5w30s, and the latest 5w30s are similar to the old 0w30s. Am I correct in this assumption?
Not quite. The latest J300 CCS spec is a slight relaxation of cold-cranking standards. Lowering the temp 5*C increases the cranking viscosity of the oil about 1.6 to 1.8 times (depending on the oil and the temp). So they reduced the temperature of the test 5*C and doubled the allowable dynamic viscosity.
The cold pumping test was unchanged. This website goes into a little more detail about the changes:
http://www.savantgroup.com/newslett/savant/jan96/jan96b.htm
[ January 02, 2003, 03:05 PM: Message edited by: Jay ]
On second thought, the allowable CCS viscosity limits didn't quite double for some grades and more than doubled for others. This compares the two standards:
code:
NEW OLD
0w 6200cp@-35 3250@-30
5w 6600@-30 3500@-25
10w 7000@-25 3500@-20
15w 7000@-20 3500@-15
20w 9500@-15 4500@-10
25w 13000@-10 6000@-5
So the standard appears to have relaxed slightly for 15w,20w,and 25w and the 0w,5w,and 10w standards are essentially the same when you consider how oil thickens at these temps.
